Headlight adjument on a LR3?
How do I do it? The right side headlight is aimed way to low. I couldnt find anything about it in the owners manual.
I poped the hood to see if I could find any obvious height adjustment control levers/screws, but I couldnt see any besides a pair of toothed aluminium like nobs on each headlight assembly. Thanks! [&:] |
RE: Headlight adjument on a LR3?
one from the top through the core support (need a flashlight) and one from the bottom inside (same) I dont know which is which I just know they are a large flat blade in a cross pattern
ORIGINAL: rinmud one from the top through the core support (need a flashlight) and one from the bottom inside (same) I dont know which is which I just know they are a large flat blade in a cross pattern Core support, hmm. whats that? [sm=smiley23.gif] When you say large flatblade in a cross pattern, do you mean as in not a philips? Thanks! |
