Hot start problems 1997 Discovery
I have had hot start problems for over a year now and I am very frustrated. I have replaced the following: Fuel pump relay, fuel pump fuse, fuel pump, mass airflow sensor, stepper motor, throttle position sensor, both coolant temperature sensors on manifold, fuel temp sensor, main engine wiring harness (worked for a few weeks), battery and crank position sensor. I have also replaced all four O2 sensors (i know, long shot, but I'm desperate). It starts twice in a row, but requires me flooring the accelerator on a third start in a row if the engine is hot. The engine cools and starts just fine after about twenty minutes. HELP!!
