-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   How to drain gas from Range Rover Sport (https://landroverforums.com/forum/general-tech-help-8/how-drain-gas-range-rover-sport-65937/)
slickooz Mar 18, 2014 02:58 PM
I work at an exporting company and sometimes we get RRS into our warehouse. We have to remove all the gas from the tanks when we export. We are having difficulty removing the gas from the RR. For other cars we just stick a long tube in the gas tank and pump it out. But the Range we have tried many times with no success.
Any help would be greatly appreciated! Thanks!
abran Mar 18, 2014 11:29 PM
Im guessing, but if the fuel pump is on the tank, Take out the fuel pump and siphon out the tank.
Good luck.
slickooz Mar 19, 2014 10:48 AM
Thanks Abran, that did cross my mind. But that seems like too much work. Someone told me you can drain the gas from under the hood, near the engine. But he was in a rush and couldnt explain it to me.
abran Mar 19, 2014 11:20 AM
Sorry, that's all I got!
04duxlr Mar 19, 2014 11:50 AM
I find that with any Rover the tank will drain pretty quickly if you DRIVE IT.
abran Mar 19, 2014 02:04 PM
Well said.
drowssap Mar 20, 2014 08:09 AM
pull the fuel line off the throttle body and turn the key on.
abran Mar 20, 2014 09:13 AM
I think the fuel pump will shut off if the engine management system does not detect combustion, but that's a guess.
jamestfl Mar 24, 2014 02:40 PM
"I find that with any Rover the tank will drain pretty quickly if you DRIVE IT."
x2! it'll even eat lots of gas at idle. what's the problem with the hose-in-the-tank siphon method?
