I am totally at a loss
Auto zone said the check engine light must be active to read the problem. Well, the 2002 discoveryII will go about 3 miles after starting (running great) then the engine light will come on at the same time the truck stalls and can not be restarted. Leave it set for an hour or so and it will start and run for another 3 miles before a repeat happens. What should I check? Help would sure be appreciated. thanks Mike
Go back to AutoZone and buy a new crank sensor, then install it.
How to change Crankshaft position sensor 2000 DII - Land Rover Forums - Land Rover Enthusiast Forum
This is a write up on how to replace the crank sensor.
