Key Fob won't work
I replaced my car battery and when i was finished my radio, windows, sunroof, clock, and key fob was reset or something. I got everything working but my key fob and i can't lock my car so my alarm doesn't work either. Someone please tell me what to do!!....thanks
RE: Key Fob won't work
Year, model and mileage????
It's a 1998 Range Rover HSE 4.6 and it has about 101,000 miles on it.
So have you gone thru the whole procedure of reprograming your trucks system after changing out your battery?
Mike |
I have resynched the windows and radio and reset the clock but as far as anything with the key fob, then no.
you have to put the key in the drivers door and while hold it turned press either the lock or unlock button. If that does not work then you will need to replace the drivers door latch
| All times are GMT -5. The time now is 01:49 AM. |
