3 warning lights at once. Help
Ok. I bought a 00 DII last weekend. I have put about 250 miles on it so far with now issues. I was driving it today and the Hill Decent Control failure light, ABS light and Traction Control light all came on at the same time and stayed on. I didnt try to turnthetruckoff then back on once I got home to see if they were going to stay on or not. But it was a bit strange to have all 3 come on at the same time. I was braking to make a turn when they came on. Lite braking. I am guessing it's an ABS issue since I'm pretty sure that the ABS controls all of these. Any opinions?
Thanks
Thanks
RE: 3 warning lights at once. Help
OK I found some old posts about this very issue. I will check everything that I can and see whats up. I am putting a new spring and shock package on this weekend and can check everything then. Maybe it's time for a brake job, but nothing squeaks or sounds bad and it brakes very well. Might be that speed sensor issue. Would that be a recall deal or just test and replace the bad one?
ORIGINAL: TD4141
ABS works fine. So now I will wait to see this weekend when I put in the new suspension what the brakes look like.
Need to find a mechanic who has a scanner capable of getting into your ABS, read and clear the codes. Lights may stay off, if they come back, then look closely at the fault codes and see which one keeps coming on, then you may need to throw a part at it.
Let us know what they find.
Yea, came on again yestersday but I wasnt able to do another ABS stop test since I was in a high end neighborhood. Of cours turned it off and the light stayed off the rest of the day. Finally had the suspension package show up today so maybe tomorrow I will get the wheels off and do a quick break check.
