Missing/Loss of Power '97 Disco
I just bought this thing like two months ago. I've been a Toyota guy up until now, so I don't know much about Land Rovers.
About a week ago, I noticed it started "missing" like it was losing power, almost like it was running out of gas. It didn't do it all the time though. Well, it's getting worse The check engine light came on. And, it's definitely not at full power and sputtering constantly. A guy told me it could be the MAP Sensor. But, that's not all. If it sits for more than a day without being started, the battery is going dead. I think something is draining the battery, maybe the starter or alternator. I guess I just have to take it to a shop to find out.
Back to the MAP Sensor: It's $700 from my local LR dealer. Anybody know where I might find a used one online or in the Tampa area?
Any help would be greatly appreciated.
Thanks,
Shawn
Thanks,
Shawn
RE: Missing/Loss of Power '97 Disco
Still didn't have time to go get the codes today. Will have to do it first thing in the morning.
On another note: When I bought the thing, the backlights for the shifter (P, N, R, 3, 2, 1 or whatever) didn't work. So, I told them and they had it fixed....NOW they stay on even when the car is off, and my heat/ac fan and cruise control back light will stay on when the car is off unless I turn the controls to off. Seems like the deuschbag wired them wrong. The garage that did the work is an hour away...
AND, I just noticed as I was getting gas:
A.) the rubber hose connecting the filler nozzle to the tank is cracked and leaking.
B.) when my gas gauge is reading empty, it only takes 17 gallons to fill up a 23.4 gallon tank...
ORIGINAL: Disco Mike
Go out this even to your local auto parts store and get your codes read, takes all of a few minutes.
By the way, that cracked hose will be throw a code also.
P0300 - Random cyl. misfire
P0308 - Cyl. 8 misfire
P1316 - Manufacturer Control Ignition misfire
P1313 - Engine misfire
Basically, I think it might just be the spark plugs and/or wires. So, I'll probably start there, unless you all think something different. I did get electrical parts cleaner for the MAF sensor, I'll do that anyway.
I've also already fixed the cracked rubber hose for now, see how it holds up. I guess it's either an overflow or air escape hose??? I've never looked closely at that before.
Definitely need to change the plugs and wires, too. I learned something new today, how to check if your plugs and/or wires are going bad: Put the vehicle in a completely dark place with the hood up and the engine running. Now, look for streaks of electricity/spark running along the outsides of the plug wires. I could see at least three different streaks running parallel to the spark plug wires. It's pretty interesting.[/align]
on
ORIGINAL: Amocat00
Just got back from there. The codes are:
Don't do anything to the MAF, you have no indicating codes showing a MAF problem and if you try to clean it, you will most likely kill it.
As for plugs and wires, OH yes, you need them.
I would suggest you order a set of 8mm Magnecor wires.
You might want to call me and let's talk about getting your truck healthy.
303-862-7680
Colorado before 8 pm.
X2 on the MAF, it will kill it. They are more sturdy than the D2, but at $600 a pop, why mess with it if you don't have codes for it?
Get some 8MM Magnacor wires and a set of Bosch +4 plugs. You will like the drive. This combo has been tested and proven to make the Rovers really happy.
www.lrrforums.com in the store, or www.apexperformance.netfor the wires. Don't get OEM wires, or you will have the same problem in a year. I did that when I first got my truck and they were bad in a year. The Magnacors have a lifetime warranty as well....
ORIGINAL: okdiscoguy
