No Lights with Keyless entry on '01 RR
Hello all. If you notice, when you unlock your truck, your dome light turns on and your parking lights blink. Anybody have the issue where you get no dome light or parking lights?? Also, no dome light when you open the door?
It happened all of a sudden. Everything else works, but I am fearful of an electrical issue stewing. Thanks for your help. PeteV |
RE: No Lights with Key less entry on '01 RR
Hmm... Does it work correctly using the key in the door ? Dome lights work OK otherwise ? Do the lights flash upon locking with key and/or remote ? Super lock work ?
Sorry for the confusion....
Keyless remote locks and unlocks the car, but dome light does not turn on; Lights do not blink. And dome light does not turn on with door opening or pressing the switch. I am not sure what the "Super Lock" is if you could describe. Thanks, PeteV |
Your interior lights may be switched off. Press and hold the center button on the dome lamp for several seconds. The instrument pack should say lights on or off. What does it say ?
Super lock is used to totally disengage all linkage to the door latch. This makes it almost impossible to jimmy the door open. If you press the lock button twice within 3 seconds it engages. You will here A second latching sound. |
Ill check and let you know. Thank you for your help. I appreciate your DIY help before trying to take it to the shop and "pay" for it.
PeteV |
