Off road light wiring
I'm thinking it's the ground though since the factory ground is real real flimsy.
I used a new premade wiring harness with all the fuses and 12v resistor. This afternoon I did a variation of the jumper cable idea. I ran two wires from one lamp to the passenger side fog lamp harness (no fog light hooked up ). Then I turned on both lights., and viola! They have the same brightness. so I have identical lights on two separate harnesses that appear to cast identical beams. Only two options left. Take it all back off, return the cheap Pilot lights back to the store and buy more expensive lights. Or just leave them on and put some decent bulbs in them. Maybe some PIAA 55 = 100 xtreme white. About the same money but one way does not involve taking it ask off and putting new stuff on .
I also have a set if KC 57's.that im thinking of mounting on the sides for alley lights
muddybuddy
08-24-2010 06:26 AM
