-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   P0441 Engine code incorrect purge flow (https://landroverforums.com/forum/general-tech-help-8/p0441-engine-code-incorrect-purge-flow-76389/)
Disco Britt Nov 7, 2015 03:08 PM
any ideas what this could be do i need a new purge valve
Joemamma1954 Nov 7, 2015 11:28 PM
When mine threw that code, I replaced it with one from Advance Auto Supply, and has been 6 months and still no code.
Hyundai uses the same one, search for it on the forum and you will find the correct number, the LR one is quite expensive.
