-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   right side low beams out? any help please (https://landroverforums.com/forum/general-tech-help-8/right-side-low-beams-out-any-help-please-59268/)
filthydisco01 May 21, 2013 10:45 AM
turn my lights on the head lights come on but no dash illumination... the air controls do not illuminate either.... the shift area does illuminate but oddly enough only when i have the headlights off as soon as i turn them on that goes out as well. Also another issue i noticed I had a tail light out so i replaced the bulb which was infact bad but it still is not working with the new bulb. Any input or help would be much appriciated a
Savannah Buzz May 21, 2013 11:40 AM
Thank you for your confidence in our Jedi mind powers to view the particular vehicle parked outside your IP address, and determine the year and model. While Rovers share many things, like a reluctance to hold their fluids, a wiring diagram is not one of them.
filthydisco01 May 21, 2013 12:12 PM
I have 2001 disco
filthydisco01 May 21, 2013 12:15 PM
Could it maybe be a relay? All my grounds are fine its just that I was connecting some spotlights and I must have mixed wires then it sparked and now no low beams on my right side
gprtech May 21, 2013 12:27 PM
Did you check all of the fuses?
filthydisco01 May 21, 2013 01:30 PM
Yes none of them are blown
filthydisco01 May 21, 2013 05:46 PM
Any other possibilities?
Ed1911 Oct 19, 2013 12:43 AM
You wire in a remote starter? I've seen a very similar issue in a 2002 that had an aftermarket remote starter installed.
