sqeuking sound while accelerating.
I have a 2000 Disco series II, there is a sqeuking sound coming from somewhere in the front of the vehicle when i accelerate and it stops after about 30 mph. Belt? Wheel Bearing? Any suggestions would help.
RE: sqeuking sound while accelerating.
have you ever replaced the front drive shaft?
No, I just bought the vehicle. I had it checked out before i bought it and the mechanic said everything looked good. I had a 2000 Xterra that did the same thing and they replaced a belt and it went away. Didnt know if it was any different with land rovers.
i hope its the belt, but i think you should look at the other threads
on this forum about the front drive shafts and inspect. |
Don't always trust a mechanic.
Crawl under the front drive shaft, flash light in hand, if the 2 u-joints in the the double cardon, that attaches to the t/case don't have grease fittings, them start by having that rebuild or replaced before it fails. |
any estimates on the cost if it is the drive shaft?
coast driveline and gear in ventura CA
rebuild my drive shaft for 191 dollars in three days. |
| All times are GMT -5. The time now is 08:41 AM. |
