-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   tire size change (https://landroverforums.com/forum/general-tech-help-8/tire-size-change-64541/)
Notenuff Jan 20, 2014 10:14 AM
tire size change
D2's came with 2 tire size options, 16" and 18". Any issues switching between the two sizes either way (up or down)? I guess the speedometer/odometer will be off? Other than obvious things such as ground clearance, looks, anything to worry about? Were the brakes set-ups the same?
dusty1 Jan 20, 2014 10:19 AM
nothing should change and no issues either way. changes come from overall diameter and size of the rubber
Notenuff Jan 21, 2014 08:42 AM
yes, I do see that the OEM available sizes have just about the exact same diameter. I just assumed the 16" would have a smaller diameter Thanks
