-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   Transfer Case Neutral "message" (https://landroverforums.com/forum/general-tech-help-8/transfer-case-neutral-%22message%22-11621/)
Bobcat9024 Jan 30, 2008 09:39 AM
Just purchased a used 2004 Range Rover HSE with 60,000 miles 2 months ago. For the last 3 days I've been getting the message on the dash "Transfer Case Neutral" only blinks on for 2-3 seconds then goes off. Only does this maybe 1 or 2 times on my 30 minute driveto work. Last night on the way home the "Transfer Case Neutral" message came on several time in a row. Then I felt the transmission shift and the dash display said something like "Transmission Safe Mode Program" Once I stopped and turned off the truck everything went back to normal, but when I returned to the highway the same thing happened.
Any help...????? or should I just bring the truck into the dealer and bend over..?!?!?!? :o)
Thanks,
Bob
Disco Mike Jan 30, 2008 09:55 AM
RE: Transfer Case Neutral "message"
Find a good independent Rover shop and have them scan the system, this is the only way to find and cure the problem.
lrobin3w Jan 30, 2008 07:32 PM
check your owners manual, and look up the section regarding, towing the vehicle. there is a fuse you can install to safely tow the vehicle without causing damadge to the drivetrain. this fuse may be in place when it should not.
raid13 Jan 30, 2008 08:59 PM
you will get a "transfer case select neutral" when one of the front cv axles
are not in all the way. have you had a front diff replaced lately?
Oberg Mar 29, 2022 03:36 PM
Transfer case neutral
I have a 97 range rover 4.0 SE Drove it no problem pulled in to park it when I put it park it made a grinding noise and then I had no forward or reverse message said transfer case in neutral checked fuse 37 and it checked out any suggestions
