Sponsored by: CARiD
Transfer Case - Paper Gasket or Hylomar Gasket
Old Sep 29, 2012 | 12:59 PM
JRover83's Avatar
5th Gear
Default Transfer Case - Paper Gasket or Hylomar Gasket
Hey All,
I have an '03 Disco 2 and pulled the transfer case last weekend, it was leaking pretty bad so I replaced all the seals and gaskets on her using a kit from Atlantic British. I purchased the Hylomar sealant as well but didn't think I needed to use it with the paper gaskets that came in the kit. Well here we are a week later and she is leaking out of the front output shaft bell housing where it seals to the transfer case housing. I can only imagine the leaks are going to get worse.
Should I just pour in some oil leak stop, or do I need to pull out the T-case again and re-do the seals using the Hylomar? or do I use the Hylomar and the paper gaskets together?
I would appreciate any advise you all have on this.
Thanks!
Old Sep 29, 2012 | 01:17 PM
Try a bottle of White Shepherd oil stop leak first before you go tearing it out again. I put some in mine nearly 2 years ago and it hasn't leaked since.
Old Sep 29, 2012 | 07:34 PM
JRover83's Avatar
5th Gear
Thanks Disco Mike, yeah the bottle is on the way. Say I do end up needing to re-do the seals again, do you recommend using the Hylomar Blue Sealant, or the paper gaskets that come in the re-build kit? or both?
Thanks,
archaeology_student
Aug 2, 2014 09:43 AM
aftermath431
Oct 17, 2013 07:53 PM
sorbet35
Feb 24, 2012 02:10 PM
willrok13
Aug 2, 2011 03:00 AM
sayre05
May 31, 2008 09:49 PM
