Transmission levels
I have a 97 disco I automatic. How do i check transmission fluid level.. I have a dipstick. Do you check it with the disco running or not???
Thanks Beth:) |
RE: Transmission levels
Beth,
Check it with the truck on level ground, with the engine running before you go and drive. Mike |
ORIGINAL: Disco Mike Beth, Check it with the truck on level ground, with the engine running before you go and drive. Mike |
