-   General Tech Help (https://landroverforums.com/forum/general-tech-help-8/)
-   -   Un-hooking the bottom of the front seat? (https://landroverforums.com/forum/general-tech-help-8/un-hooking-bottom-front-seat-43540/)
trimblej3 Sep 6, 2011 06:51 PM
Hi,
I am trying to install dvd headrest units in my 2007 RRS and need to run the wires down the headrest holes to the bottom of the backside of the front seats. I cannot figure out how to unclip, unhook, detach the bottoms of the seat. Can anyone give me some fairly detailed instructions on the process and/or have a diagram they could post showing the procedure? Thanks so much in advance!!
Banzai Jimmy Sep 6, 2011 08:14 PM
Have you tried something along the lines of straightening out a coat hanger and probing down the back of the seat to see if you can find an exit? If so, then tape the wires to the hanger and pull them thru.
trimblej3 Sep 7, 2011 07:39 AM
yeah, but it is super tight and there is just a small hole on each side of the bottom of the seats. It would make the job much easier if I could figure out how to unclip the bottom flap. I can see were it gives a little and there appears to be a plastic clip that runs the width of the bottom of the seat. I cant find any specific info on the range rover sport seats or the LR3 (assuming they are the same seat) on how to unhook them. From what I've read on most cars the upholstery does unclip and reveals a flap and when you are done you just reclip it. I saw a similar post on a forum about a LR4 but it had no responses.
