Originally Posted by Forrest Hawk
(Post 749088)
https://cimg8.ibsrv.net/gimg/landrov...e492ceb4dc.jpg
https://cimg5.ibsrv.net/gimg/landrov...4179b79ebb.jpg |
That's actually great news
I would do the following 1. Mark the relay in position 49 with the letter B (use a sharpie) B = Bad 2. Swap the bad relay in position 49 with the Relay in Position 29 (Note: this will likely disable the heated defrost on the windshield) 3. Start you LR2 like you did before all of this happened (let us know if it starts) 4. Get a new relay for the bad one I bought a Wells 20999 (But a Duralast 20999 should work fine https://www.autozone.com/electrical-...20999/448812_0 ) Other sources for the relay https://www.rockauto.com/en/parts/wv...wer+relay,2944 I've been running the Wells 20999 in my LR2 since 2012 and it starts every time. I swapped my relays in 2012 because my original battery died (it was 5 years old) and as the voltage dipped one of the relays became unstable and it switched on/off about 50 times a second for 60 minutes that's about 200,000 cycles which is likely all that the relay was rated to do. I didn't know which relay had become unstable so I replaced all of them. Good luck Paul PS When my battery died I couldn't even remove the key from the slot, all I could do is listen to the relay clicking away, I was very annoyed, but since then my LR2 has been very reliable. The important thing to remember is that the LR2 won't suffer fools, you need to be proactive. |
For the Gray Relay
Land Rover - Relay part number LR003751 (if you go to the dealer you will need this number) Cross reference - drop in replacement part numbers 1R2395 20999 I still have two Gray relays that I removed 8 years ago if you were 3,000 miles closer you could have them |
Originally Posted by p_gill
(Post 749094)
I would do the following 1. Mark the relay in position 49 with the letter B (use a sharpie) B = Bad 2. Swap the bad relay in position 49 with the Relay in Position 29 (Note: this will likely disable the heated defrost on the windshield) 3. Start you LR2 like you did before all of this happened (let us know if it starts) 4. Get a new relay for the bad one I bought a Wells 20999 (But a Duralast 20999 should work fine https://www.autozone.com/electrical-...20999/448812_0 ) Other sources for the relay https://www.rockauto.com/en/parts/wv...wer+relay,2944 I've been running the Wells 20999 in my LR2 since 2012 and it starts every time. I swapped my relays in 2012 because my original battery died (it was 5 years old) and as the voltage dipped one of the relays became unstable and it switched on/off about 50 times a second for 60 minutes that's about 200,000 cycles which is likely all that the relay was rated to do. I didn't know which relay had become unstable so I replaced all of them. Good luck Paul PS When my battery died I couldn't even remove the key from the slot, all I could do is listen to the relay clicking away, I was very annoyed, but since then my LR2 has been very reliable. The important thing to remember is that the LR2 won't suffer fools, you need to be proactive. I will am ordering the replacement relay and I will post an update once installed. Much appreciated 💋 |
Any update????
(Post 750024)
Any update????
I just recieved the new relays & when replacing them I noticed that one of the female's you had instructed me to switch places with was burned out so I am replacing it as well. The battery has been disconnected since I last attempted to start it, do I need to wait any amount of time after reconnecting it before I attempt to start it? |
(Post 750110)
Good morning,
Also I would charge the battery if you have a charger.
Let us know what you find out Thanks Paul |
(Post 750119)
Let us know what you find out Thanks Paul https://cimg7.ibsrv.net/gimg/landrov...4014e344d1.png Fuse that blew when i attempted to start rover after replacing with new one, at same time i replaced relays 46 & 49 with new one's. |
Sounds like you may need a new starter.
