2008 LR2 wont start
Old 05-19-2021, 09:38 AM
flybd5's Avatar
I absolutely DO NOT recommend doing that. For 5 to 30 amps, ok, but for a 150 amp fusible link? That's just asking for trouble. If you don't do it exactly like the manufacturer, you risk a fire and that near to the battery, an explosion.
guy (01-09-2022)
Old 05-19-2021, 09:52 AM
merlinj79's Avatar
Something like this should be safe enough, it's sealed and designed for vehicle use. Just cut off the fuse part of the existing harness and attach to the cable ends. Allows easy replacement of the fuse for the next time your starter shorts out. You could further protect the thing with electric tape and/or wiring loom.
Link:
Amazon Amazon
Old 05-19-2021, 09:59 AM
flybd5's Avatar
Link:
https://www.amazon.com/InstallGear-G...921483352&th=1
I've been working with this kind of thing (high amperage DC and AC) since late 70's when I trained for it in the Marines, on medium and heavy cargo helos. The fusible link on the factory cable is soldered, and it's that way for a good reason. You want as full contact for current passthrough as possible. The one on the link is a screw-down terminal. Not nearly the same thing. Bad idea. Trust me on that. The real thing is not expensive enough to warrant taking such a risk.
The following 2 users liked this post by flybd5:
guy (01-08-2022), Ham803 (01-08-2022)
Old 01-08-2022, 10:31 AM
Mark P's Avatar
Default Where is this fuse located?
Originally Posted by Ham803
So after replacing the starter with a new OE starter and a new battery just in case with 850 cca. I checked the fuse leading from the battery to the starter. It showed it had current going through it. I jumped it off just in case and tge vehicle started. So I took the cable off and looked at the fuse. It had a hairline crack in it. Just enough to have current going through it but not enough to crank the vehicle. Thanks everyone for your help and maybe this will help other people as well.
how far off the battery terminal? Having a battery drain issue and wonder if this might qualify as a reason.
Ham803 (01-08-2022)
Old 01-08-2022, 10:34 AM
flybd5's Avatar
A crack in a wire is not the same as a crack in a water pipe. No electricity will drain from a crack in a conductor of any kind unless it is shorted to ground, and in that case the symptoms will be VERY noticeable.
Mark P (01-08-2022)
Old 01-08-2022, 12:45 PM
ThorInc's Avatar
Check you ECM relay modules?
Old 01-08-2022, 12:58 PM
Mark P's Avatar
I have not yet nor do I know how. Just starting to try and locate the problem.
Old 01-08-2022, 01:21 PM
ThorInc's Avatar
Google is your best friend here:
HOW TO TEST A RELAY
But before you do, try the HARD RESET laid out in post #3
Mark P (01-08-2022)
Old 01-08-2022, 07:54 PM
Ham803's Avatar
Default Troubleshooting
Mark P try and jump around that fuse. Take a piece of 6 awg wire and jump around it while someone hits the start button.
Old 01-08-2022, 07:56 PM
flybd5's Avatar
...and make sure a second friend points a fire extinguisher at you, just in case!
Mark P (01-08-2022)
Quick Reply: 2008 LR2 wont start
