2010 Land Rover LR2 Transmission Fluid Change
#31
#32
#33
The maintenance schedule for the LR2 calls for the transmission fluid and filter to be changed every 10 years or 150,000 miles or about 240,000 km. Same for the transfer unit and rear differential oil. Then again, if you are going to remove the transmission fluid pan and haven't changed the filter recently, you might as well change the filter as well. They are not expensive, but it's not something you change as often as the engine oil filter, unless you have symptoms that might suggest the filter might be clogged.
#34
Questions
Firstly I would like to say thank you all so much for the information provided. I have bought a 2011 lr2 hse last year and have had around $4000 in work done to it, Halex pump went and new front end coils and spark plugs. I’ve put about 40k kms on it and it’s at 155k kms. I’ve called transmission shops and they will not work on land rovers and I have a feeling the transmission fluid has never been changed. I have no real way of checking the temperature of the transmission oil and after buying all the tools (torx wrenches, fluid, gaskets I don’t really have a bunch of cash leftover to buy a fancy obdii reader. Also nobody really mentioned how they got the fluid way down into that fill plug hole. Lastly I have ramps I use to work on the car and it needs to be on a level surface to do the final drain. Wondering if you genius’s have any ideas to help me with some of the obstacles I’m facing. Thank you again for all of the insight so far, I really want this vehicle to last.
#35
An Autel AP200 reader that understands Land Rover-specific diagnostics is $55.
Checking the temperature can be done with an infrared temperature sensor. $18.99
Transmission fluid pumps are also cheap.
To make it level when you raise it use four jack stands and a floor jack. For that, hit Harbor Freight tools. In fact, if you have a Harbor Freight Tools nearby you can buy all this stuff there except for the Autel reader.
#36
If you have four ramps, that should work. Alternatively if you don't want to buy more ramps or jackstands, drive the fronts onto the ramps, and then jack each side and place layers of plywood or bricks under the tires to get it all level. By bricks I mean bricks, not cinder blocks or anything hollow, those can shatter which would be bad.
tblanch258
10-31-2013 04:17 PM
