2010 LR2 Keyfob unlock stops working
2010 LR2 - After 10ish days, if not used, it seems that the key fob will not unlock the doors. I have to use the physical key, unlock the door, alarm goes off, insert FOB. Starts normally.
Any idea what is happening there? I was thinking it might be the key fob, as I understand it charges when docked, but it works to unlock the doors immediately after opening and starting the car, so it doesn't seem like it would get much charge.
Thanks,
Tom
Thanks,
Tom
https://www.freel2.com/forum/topic32858.html
Have fun
Paul
EDIT: Do any of the buttons on the FOB work when you are trying to unlock? For example can you turn on the headlights? Open the rear hatch? Lock again and get the corner lights to flash?
When you press the plastic housing the plastic bends and the + comes into contact with the micro-switch on the printed circuit board. For my remote 10 years of cycling was enough to wear away the + and cause the remote to not work as intended.
Paul
