2013 lr2 blower motor squeaking
Hello again. The blower motor has developed a squeak on lower speed settings. I can't seem to find much info on replacing this. What I have found looks like a pain to replace, but thats on a 2012 model. Wondering if someone has information or a video for the 2013 model? or any diy solutions? Thank you
It's a PITA to re and re and you will need a special tool to simplify removal.
Check out this band-aid solution: Lubricating the Bearing for the HVAC |
I did the drill and lubricate trick. It helped some initially, but then over the course of several months it got even quieter, so it may take time for the lube to get in there.
I couldn't fit a spray can in there easily right side up, if I need to do it again I may try a small squeeze tube of Li grease. |
