2013 Lr2 code p2281-21
Have service code p2281-21. minimum air rate detected. Have checked all plumbing for air leak. none found. Has anyone run into this problem on this engine. Im pulling my hair out on this thing. I know believe we may have a Oil separator leaking air internal ????? Please advise if anyone has run into this.
It means you have an air leak between the MAF and the throttle body.
https://www.obd-codes.com/p2281 |
