2013 LR2 won't turn on
Lights and radio, everything turns on, but the car. I hear a click when I push the start button somewhere to the right of me. Is this the starter? Could it be a fuse (I checked F15 in the engine fuse box diagram is for motor starter). The sound also feels like it's coming from the passenger side fuse box. I used a portable battery with the hope that the car battery just needed to be charged but still, no go. Any thoughts?
The click comes from a relay in the ECU behind the glove compartment. Check the battery with a tester. A local auto parts store will usually do it for free. Obviously, if it tests bad or even if it tests borderline, replace the battery. The LR2 is very sensitive to voltage.
If the battery is good fully charge the battery before using it again. A portable battery does not charge your car's battery. Remove the terminals from the battery before charging and set them up so they touch while you charge the battery, that will discharge all the control boxes and reset any potential errors.
If that still doesn't work put a code reader on it that understands LR modules and post the codes here. You can get the codes read at the auto parts store.
This LR2 can kill a discharging battery in two years, yes. It's a battery hog if the vehicle is just sitting without daily or longer drives. And to the second Q, yes. If you have the time and effort, try removing the front "bash plate and whacking the starter with a rubber mallet and then try starting it or get two people and try it in synchronicity.
Age of the battery is irrelevant except for warranty purposes. Get it tested. If the battery is fine remove the starter and get it tested too. It's easy to get to.
guy (08-16-2023)
Thank you for all of your help, it ended up being the starter. I brought it to a guy who had it replaced and fixed an oil leak somewhere around the transmission. I paid a total of $500 Canadian. Do you think that is reasonable?
You already paid. The time to ask if it's reasonable is before you pay. I have no idea what the going rate for labor is in Canadian shops.
Tommylr22013 (08-18-2023)
Flybd5,
I also am running into a weird issue with my 2015 LR2. Wife drove it to the bank, came out and no start. Car will make its relay "CLICKING" sound, but no good.
vehicle has 100,000 miles, so for ****s i went ahead and changed the starter/solenoid assembly. Still no good, checked SM 40a fuse checked good. checked SM relay, switch opens like normal. went ahead and pulled the 3 week old battery and charged. charger did say it was down to 65% at the time of charge. Charged battery, and installed again. Still no start, same relay clicking noise.
ANY Thoughts are welcome my way!
Flybd5,
