Air in Power Steering Line
Old Jan 13, 2018 | 11:31 AM
Davecz's Avatar
4th Gear
Angry Air in Power Steering Line
I have a 2008 LR2, justed changed the Power steering pump, however I have a lot of air in the Reservoir. When I start the engine and turn the wheel left and right the oil drains out of the Reservoir then when I turn off the engine the oil returns to the reservoir in a few minutes to the same level it was previous.
Any suggestions on how to "bleed" out the AIR?
Old Jan 17, 2018 | 10:41 PM
loanrangie's Avatar
Does it have a rack & pinion system ?, should be a bleed valve/screw somewhere.
Old Jan 18, 2018 | 12:19 PM
DavC's Avatar
Explain exactly what you did.
The rack and pinion on another car I am familiar with is (LR3/Discovery3)
>Pull the non pressure hose at the rack to drain all fluid if changing
>reconnect hose
>refill reservoir to max line
>start car
>turn steering wheel to left lock
>turn steering wheel to right lock
>shut off car
>check level
>repeat a few more times
If you replaced the pump I would imagine you'd try and prime it before you hooked everything up.
What I imagine you did was just not do it fully or not do it enough times to bleed all the air. YMMV
Dane!
Nov 8, 2013 05:57 PM
orionpaxx
Nov 7, 2011 10:07 PM
JerrodSteph
Jun 12, 2011 06:04 PM
nickd503
May 16, 2009 05:18 PM
FordCrusherGT
Jan 10, 2007 02:15 PM
