-   LR2 (https://landroverforums.com/forum/lr2-35/)
-   -   Bolts to put engine on stand (https://landroverforums.com/forum/lr2-35/bolts-put-engine-stand-127629/)
flybd5 Jan 14, 2026 08:09 PM
Does anyone know what size bolts I need to mount the engine block on a stand? Are they M14x1.5? I'm picking up my old engine from the mechanic on the 23rd and I want to transfer it to the engine stand after removing the flywheel, cover, etc.
LR2driver Jan 15, 2026 10:56 AM
To be sure, you may need to visit your local Volvo parts dealer and ask them to lookup the bolt size for the B6324S engine. Does the stand attach using the same bolt holes as the transmission?
flybd5 Jan 15, 2026 11:01 AM
Harbor Freight Tools engine stands have universal adapter mounting plates. I will check with the volvo dealer. thanks!
flybd5 Jan 15, 2026 11:29 AM
The local dealer had no clue, so I checked with a bolt vendor and I found out that sells a set. It comes with the four correct M12x1.75x105mm bolts and an additional set of four M10x1.75x100mm for smaller engines.
