Low Coolant Level
Old 09-25-2017, 05:40 AM
Can Baykara's Avatar
Default Low Coolant Level
Hello guys,
I am getting low coolant level warning each week. I know that there is no fault in sensors because i am adding 1 liter of water each week. The engine is opened and revised and turbo is changed. This solved the low performance problem. Now there is no problem about the performance but decreasing water level. It is a 2.0 Si4 engine LR2. What are your advices?
Best..
Old 09-25-2017, 05:49 AM
Head gaskets also checked..
Old 12-05-2017, 10:09 AM
z1234567890's Avatar
You need to check leakages, especially the coolant hose and radiator itself (on plastic/rubber part), what I would recommend don't simply add water, add coolant (that pink-orange-red color) mixed with distilled water (50%:50%) when it leaks it will leave pink-orange color
Old 01-27-2018, 11:27 AM
abfoster's Avatar
Default Low coolant
I had the same problem. There are numerous hoses. I found the lowest hose had a small leak in it. I was hard to find. Had to remove the skid plate. It was a fine little slice. Almost like someone took a small knife and pierced a small slice in it.
Old 02-18-2018, 08:08 AM
hichamaziz's Avatar
Scrappyq99
LR2
11-25-2016 02:05 AM
gillart
01-22-2015 03:35 PM
Ajibola
03-27-2012 07:34 AM
mwood2121
07-14-2011 07:39 AM
MikeLi
09-18-2008 10:33 AM
Quick Reply: Low Coolant Level
