Drain hole added to front power transfer unit
Old 01-17-2017, 01:00 PM
p_gill's Avatar
Default Drain hole added to front power transfer unit
All,
As some of you know its very difficult to remove the Gear Oil from the front differential on the LR2 (Freelander 2)
After some research on the internet I decide to make my own drain.
I removed one of the bolts that joins the side flange to the main casting and I drilled out the back of the hole so that the oil would drain out.
Standard disclaimers apply, if you want to attempt this modification on your vehicle you do so at your own risk.
I drilled a very small hole about 1/8" so that I didn't interfere with the threads in the casting.
My LR2 is a 3.2 Volvo 6 cylinder but the procedure should be similar for the diesel.
Its not obvious in the pictures but I raised the LR2 from the opposite side so that most of the gear oil would drain out.
To seal the hole I just reinstalled the bolt.
If It leaks I will install a Copper washer or Aluminum washer in place of the steel washer.
Enjoy
Paul
Attached Thumbnails Drain hole added to front power transfer unit-img_2374.jpg   Drain hole added to front power transfer unit-img_2380.jpg
FFJ
11-11-2015 11:53 AM
NickDII
01-23-2012 12:00 PM
timdunbar
11-06-2010 07:14 AM
audiS4S6
05-06-2010 12:14 PM
freewheelin
09-18-2006 08:39 AM
Quick Reply: Drain hole added to front power transfer unit
