Help with fault codes
Hello all, new to the forum and hoping someone might be able to help me.
We have a 2008 LR2 which has been functioning perfectly, all of a sudden the check engine light came on. We got the codes read and it came up with three codes -- p0458,p0057 ,p0051, It seems there must be something common causing all of these.. They all seem voltage related. Any ideas ? Where can I start looking to try to diagnose this ? Any help appreciated as I do not know where to start. |
Wow, no one has any idea ?
I guess this is rare. |
When the battery gets old electrical gremlins show up how old is the battery? for my LR2 the fuses in the engine compartment got corroded when my battery failed i replace all of my fuses i also replaced a few relays get a copy of the electrical diagram and check what’s in common with the codes here is a video of a Volvo owner that did exactly that note: the xc90 in the video has an almost identical engine to the 3.2 in your LR2 and the electrical system should be very similar if not identical good luck paul |
