Intake manifold gasket
Dear members ,
Im gonna replace the intake manifold gaskets on my LR 2 2009 to fix a vacuum leak , the OEM gaskets are a bit expensive , I found aftermarket Vector Reinz gaskets online . Has anyone used this brand ? Is it recommended ? |
Dear members ,
Dear members ,
Im gonna replace the intake manifold gaskets on my LR2 2009 to fix a vacuum leak , the OEM gaskets are a bit expensive , I found aftermarket Vector Reinz gaskets online . Has anyone used this brand ? Is it recommended ? |
Originally Posted by Hamza89
(Post 753970)
Dear members ,
Im gonna replace the intake manifold gaskets on my freelander 2 2009 to fix a vacuum leak , the OEM gaskets are a bit expensive , I found aftermarket Vector Reinz gaskets online . Has anyone used this brand ? Is it recommended ? |
Originally Posted by flybd5
(Post 753971)
Which OEM part number are you talking about?
As a suggestion, you may get better results if you posted in the correct Freelander Forum as opposed to starting three separate threads in the incorrect forums.
Originally Posted by ahab
(Post 753973)
thanks for understanding . |
Wrong section mate. Try The Freelander section up the road and to the right next to the Circle K....
Welcome to the forum.
Ja! Victor Reinz make good gaskets but I don't own a Freelander. |
Originally Posted by JUKE179r
(Post 753978)
