-   LR2 (https://landroverforums.com/forum/lr2-35/)
-   -   LR2 - Random Fault Codes (https://landroverforums.com/forum/lr2-35/lr2-random-fault-codes-60047/)
taylorm334 Jun 25, 2013 09:51 AM
2008 LR2 w/ 64K miles. All services are up to date per Land Rover guidelines.
Issue occurs about 2-3 Times a week upon start up, the LR2 will throw a HDC Fault or a transmission fault. It drives perfect and runs very smooth so nothing in that regards is affected. The error goes away if you restart the vehicle. My indy shop pulled the codes and reset everything. They mentioned it could be a bad sensor. Any thoughts?
Battery is brand NEW! So I ruled that out first!
LR2driver Jun 25, 2013 08:42 PM
What are the ODB2 codes you are getting?
