Lr2 won't start
My lr2 would struggle to start a few days ago when I pressed the start button and has progressively worse. Now it won't start at all. All of the lights come on fine however it won't turn over. In fact it won't even attempt. I just bought a new battery, hoping that would fix the problem, but it didn't........same problem......won't start. Any suggestions?
make sure its got power at the starter and starter switch. its under the vehicle so its easy to access. if you don't and the security light is off then you got to diagnose it from here.
but I recall we had a bcu update that solved the same problem so get it towed and see if the repair was done. |
Did you ever resolve this?
