no crank, no obd but hazard flasher
#21
ok, will do
meanwhile I tried another idea: pinoff CAN HIGH at the two connectors nearby CJB (footwell) and ECU (AJB) and connected them directly. all other connetion stayed original. same ...
does a short cuircut cases a hazard flashing? and why I got not connection to the ECU? must be the last cm's of cable with stayed orignal -> means back to your adivse @flybd5
#22
hi once again ... today I thought about and I understood the hazard light can be activated by two thinks: the RCM oder anti theft.
RCM is currently disconnected, so that could fire a mistake.
than I saw the anti theft indicator light is the dsahboard is not flashing ... I unlooked the car with the fob and opened the driver door. of cause the others still are locked. as I closed the driver door, the other door getting unlocked!! thats scarry and say me, thats must be the same reason why it's flashing by connection the battery.
any ideas for this behavier or where I can start searching?
#23
From memory, I had an issue once after flashing the dash with a custom flash made for SDD ( it added, avg speed, current speed, speed, mpg data, etc. and also recalibrated the temp gauge to instantly respond to temp changes, linear). For some reason, the SDD subroutine after the module flash of clearing all obdII errors must have failed. The car would not turn over, nothing but the lights would come on. Freaked me out since my first thought was, I bricked the beast....RIP as Landy would be sticking their hands real deep into my very deep pockets to begin with.....I have short hands.
Anyway, I noticed the pattern of the flashing red light had changed from the normal pattern. Maybe the module flash had triggered the immoblizer. I would scan with software and hardware that can read all errors and clear them.
Was the suv ever in an accident?
#24
hi, no accident as I know ... bought a long time ago second hand.
but my problem is I cant connect to OBD, too ... means there must be something which interrupts the bus, too. thats the scary think. I tried to bypass the ECU directly from the CJB, without success.
At moment my idea is, something disturbs the CJB ... or a break (I saw nothing) in the cable from last connectors to the CJB/ECU
#25
#26
It sounds like you have not tried SDD with a Mongoose cable or an LR-aware scanner like the Autel AP200. You need to try one of those to verify for yourself that the diagnostic connector is really dead. OBD alone won't tell you that because it is not trying to talk to the vehicle on the signal lines other than those used for plain OBD.
#27
said done ... you are 100% right!
I got a short posibility to use a autel ms reader with partley success. not all communication, as LR official me told, is dead!
I think it's easy to understand the problem, see attached. the RCM is not avaiable, too. for me look like a short circut?
LR2 DTC
LR2 DTC
flybd5 (11-04-2023)
#28
#29
#30
of cause it had a lot of errors stored as I tried to read while some disconnected CM. I tried to delete everything ...
Last I received this:
(sorry for late delivery, in the first moment I thought I only can get a foto of the screen)
EDIT: finally I'm not sure if it's the last scan. because of ABS and TCM have been disconnected ... but RCM i never could reached. sorry for the confusion, I had not that much time with the device. but short to ground or something like this for me sounds plausible. there has been some works on the engine before, perhaps demanged a cable
flybd5 (11-04-2023)
