Steering wheel noise
覧 2012 land rover lr2 hse / 146 k / 3.2 engine 覧
Hi fellas
i got a new problem about my power steering ,
couple days ago my power steering made noise
what i did ;
pressure test
check hoses
change power steering pump with new one
change fluid with chf 202 fluid
and still same noise ..
then i thought that pump has defective changed again with new one
but still same issue same noise
i did not change Steering Gear/Rack Power Rack And Pinion
I dont know what other options for this issue . For now i ordered power steering fluid reservoir it s going to come couple days later
should i change Rack and Pinion do you have any idea or advice for me
Thank you
Power steering pump
Hi fellas
what i did ;
pressure test
check hoses
Thank you
Power steering pump
Probably should bleed it thoroughly to make sure all of the bubbles are out too.
Replace res and refill first.
Then with the front wheels jacked up start by turning the steering wheel back and forth stop-to-stop multiple times with the engine off. Then repeat with engine on. You can also do it with wheels on the ground, just going to need arm strength with the engine off.
