Originally Posted by BlairMaynard
(Post 777840)
EDIT: Nobody seems to use a torque wrench here, which makes me nervous because the housing looks plastic -- manual says thermostat housing bolts require 10 Nm or 7 lb-ft torque. Probably going to be tough to get a torque wrench on the lower bolts.
Originally Posted by merlinj79
(Post 777939)
You can "calibrate" your wrist... use the torque wrench on a larger bolt (or a bolt in a vise) to get a feel for the torque you need, then just torque it by feel.
(Post 777840)
As far as I can tell, there is no need for intake or radiator removal, though these are Volvo XC90s, and looking at my LR2 it appears access from the left may be a bit worse.
EDIT: Nobody seems to use a torque wrench here, which makes me nervous because the housing looks plastic -- manual says thermostat housing bolts require 10 Nm or 7 lb-ft torque. Probably going to be tough to get a torque wrench on the lower bolts. |
Originally Posted by flybd5
(Post 777944)
You have GOT to be kidding me.
The "calibrated wrist" suggestion was for people who might not have that feel and need to avoid torquing a plastic inset nut to 30ft/lb. Structural bolts of course need to be torqued with a wrench, in the right order, and that includes valve covers if you don't want leaks. |
"Calibrated wrists" never work for bolts that have torque specifications. At best that is asking for trouble, at worst that is looking for an accident. That's the difference between an "experienced gearhead" amateur and a trained mechanic. Basic torque wrenches are $20 at Harbor Freight, less than the cost of one full tank of premium gas these days. There's no excuse not to have one if you are going to do your own work on a car.
(Post 778068)
I use bar torque wrenches because I have no easy way of keeping click wrenches calibrated. Bar wrenches can be hard or impossible to read in tight spaces. But your point is valid too, no harm at all in using book values and a torque wrench for everything, and that might save a stripped thread or two. Absolutely mandatory for engine/tranny mechanicals, blocks, cases, suspension, brakes. |
Even torque wrenches with expired calibrations are better than "calibrated wrists". Always. And you don't need to go to a shop to calibrate your torque wrench anyway.
https://www.wikihow.com/Calibrate-a-Torque-Wrench |
(Post 777840)
As far as I can tell, there is no need for intake or radiator removal, though these are Volvo XC90s, and looking at my LR2 it appears access from the left may be a bit worse...
If I were to try this, I think I would remove the upper strut to provide a little more elbow room. It comes off/on easily as I discovered when I replaced it earlier this year. And move the windshield wiper fluid filler neck out of the way, as well. I would also replace the upper hose at the same time (it's probably due anyway if you're replacing the thermostat). This way, I don't have to remove the old hose from the old thermostat while it's still on the engine, and I can attach the new hose to the new thermostat before reaching in to bolt on the new thermostat. |
Originally Posted by LR2driver
(Post 778316)
The XC90 has quite a bit more access space than the LR2. The LR2 manual says to remove the Intake Manifold to reach the thermostat. But as you suggest, that may not be necessary.
If I were to try this, I think I would remove the upper strut to provide a little more elbow room. It comes off/on easily as I discovered when I replaced it earlier this year. And move the windshield wiper fluid filler neck out of the way, as well. I would also replace the upper hose at the same time (it's probably due anyway if you're replacing the thermostat). This way, I don't have to remove the old hose from the old thermostat while it's still on the engine, and I can attach the new hose to the new thermostat before reaching in to bolt on the new thermostat. I was thinking about removing the fuel rail bleeder valve, but I don't think that would give me much more space. Yeah, I had to move the windshield wiper tank when I changed the oil a while back. I may need to disconnect it completely and remove it for this job. My thermostat housing comes today or tomorrow, so the fun begins.... |
See this thread by flybd5 for instructions on removing the upper strut (aka, torque mount). If you have a skinny arm, you may be able to reach in without removing it, so of course try that first.
https://landroverforums.com/forum/lr...-lately-99534/ I don't think removing the fuel rail bleeder valve will gain you any space (not sure if we're even referring to the same thing). If you replace the hose at the same time, you don't need too much space since you're only dealing with the bolts on the thermostat. A small articulated ratchet wrench may do the job. Good luck and let us know how it goes! |
