Transmission fluid fill plug access
Old 03-10-2019, 07:27 PM
TouchdownAuburn's Avatar
Default Transmission fluid fill plug access
Recently I tried to check my transmission fluid level and ended up draining out about a quart before getting the plug back on. However, now I’m having trouble reaching the fill plug. Has anyone had this problem and how did you fix it? If I remove my battery is there anything I have to reset or can I just reinstall the battery afterward and be good to go?
Old 03-17-2019, 09:14 PM
p_gill's Avatar
The fill port is a Torx T55
remove the air box to get to the fill port
see this link for more info
Freel2.com - View topic - Automatic transmission fill plug location
good luck
Paul
ThorInc (03-18-2019)
Old 03-17-2019, 11:14 PM
It wasn’t that easy. The AC compressor is directly above the plug. There’s actually another plug on the side of the transmission above the left axle. Because of the angle, it took awhile to fill but it was easier than removing the air filter box and the AC compressor. Even then the plug on the top is partially under a mount.
Old 03-18-2019, 11:43 AM
p_gill's Avatar
Take a look at this PDF
Can you identify which port you used?
File Type: pdf
stillruns
09-08-2018 08:18 PM
dlorraine
08-25-2018 12:40 PM
DAMINK
08-18-2015 04:09 PM
jdelp
09-20-2007 11:23 AM
Quick Reply: Transmission fluid fill plug access
