Trouble Code P0087
#21
Ok... So after installing the new sensor there was some slight differences.
Cold start 60psi
2 mins (or so) 55psi
BUT... during mild acceleration the pressure remained at a VERY stable at 55psi
Hard acceleration there was a slight/instant spike to 58 psi but dropped AND held stable at 55psi.
Hot shut down the pressure dropped to 37 BUT actually increased to 38psi - 39psi - 40psi every 90 seconds or so (I would assume from heat soak}? That I didnt notice with the original sensor. I also would assume that rules out the pressure regulator being faulty?
Now... It did seeem to drive smoother especially mild acceleration thru 2nd gear up thru 3rd and 4th. Almost more linear feeling. According to the OEM manual the fuel rail pressure is to be manitained at a stable 55psi. Except for the cold start/fuel temp 60psi situation from what I can find... VERY HAPPY with results!
Cold start 60psi
Good Luck
Paul
