06 HSE LR3 water coming inside front floor mats
I have own my LR3 now for about 7 months and 4 days ago there was a thunderstorm that hit the town where i live, i notice that the front floor was really wet somehow water got in my vehicle, ive heard about water drainage and stuff like that where can i find these water drainage thanks..
passenger side footwell damp
Does anyone know where the ac drain pipes are located underneath the truck? I have warm water on my passenger side floor, I heard that it can be caused by ac pipe blockage. I was told to put a screwdriver up into the drain pipes to clean them out, my problem is that I can't locate them under the truck. Do I need to remove the skid plate to get access to them? Thanks. Sorry to hijack this thread. Any pics??
Found ac drains and easy access to drain
The best way to drain your ac tubes in your LR 3 is from the inside. I just went to the hardware store and got a 3ft long small cable. I placed duct tape at the end so not to snag the tube on the way down. I just fed it through from the top and out the bottom, ac tubes now cleared. You have two, one on either side of the center console. Clear both, because if one's clogged i'm sure the other is on its way. Thanks bbyer for your help.
1 Attachment(s)
and a TSB for A pillar leak
Water still in passenger side foot well???
Ok I tested the sunroof drains and they drain fine, the ac drains are unclogged, I vacuumed up the water, seemed to be dry and then after driving around the floor seems damp again, no rain or snow here??? Can there be water still under the floor carpeting that I didn't vacuum up? (There is a pretty big pad under the carpet that can act like a sponge?? Possibly thawing out)The carpet also iced up when the weather was 6 degrees here.
Water may be pooled under carpet
I had a hose pop off a connection through the firewall near the driver side leg. After I repaired it, I vacuumed the water through the carpet until it was quite dry. The next day it was soaked again. I pulled the carpet up this time and found LOTS of water pooled under the carpet. Once I vacuumed that up, problem solved.
How do you lift carpet..passenger side
Originally Posted by mroorda
(Post 374815)
Originally Posted by mx468
(Post 375727)
I think thats the problem I have. I vacuumed up the water and it seemed dry and then a couple days later wet again. No rain, snow etc... I also did the a pillar fix, so its not that.... How did you lift up the carpet? Procedure? Thanks....
| All times are GMT -5. The time now is 01:51 AM. |
