Ahhhh.....okay then yeah they shouldn't have, because they don't work for $hit! Hahahahaha.
Clearly, it's Saturday afternoon and I've started drinkin'.....I've just had poor results with an AGM, that's all. Take it for what it's worth. |
2006 Alternator/ charging issues continue!
(Post 884316)
It is really bad advice to disconnect a battery on a running vehicle. It it well known you can damage the computers. The battery acts as a capacitor, in a way, to level the voltage. When you disconnect it does cause a voltage spike. If you continue to have issues, check or replace the 400amp main fuse. It is usually in a little slim black box right next to the positive battery terminal. These can develop a hairline crack and cause issues. Or you can have corrosion within that box.
There is a 400 amp fuse at the positive battery post. I have seen a few LR3 missing this though.
https://cimg3.ibsrv.net/gimg/landrov...ab5f2a37c9.jpg |
2006 LR3 charging issue
(Post 886966)
Take it all apart to look for corrosion. You may also just want to replace the fuse, any auto place would have them. Just incase the fuse itself is bad. I doubt if it is a belt/tension issue. Pretty easy to check though, maybe sure the belt is not cracked a ton and make sure it is not super easy to pull/push. It will move, just not much as you fight the tensioner.
I changed both the tensioner (complete unit ) and the idler pulley recently when i replaced the waterpump, coolant outlet and belt - single belt on the TDV6.
16 years and 235k klms on the originals and all looked/felt good as new apart from the waterpump that started leaking, worth replacing if original for peace of mind. |
2006 LR3 batt/alt
The belts look good and are very tight, and when I did the alternator the tensioner seemed like it was doing its job, but I thought maybe when it is under duress it is not. But I will check that fuse and probably just replace to see if that is an easy fix. And it is possible that the remanufactured alt is a dud. It’s a Bosch like the original but not a “brand new part”!
Thank you all for your replies. |
2006 LR3 battery/alternator issue
(Post 886970)
Fully charged battery should read 12.6 volts, maybe 12.8 initially. If that is the case, and alternator is putting out 14 volts, I would say that part of the system is good.
Voltage too high codes would worry me. Although is this the tread that mentioned disconnecting the battery when running? If so, that would cause that spike. But if those codes come back, the alternator needs to be replaced for sure.
| All times are GMT -5. The time now is 06:37 AM. |
