2006 LR3 Fault code help!!!
Hello All,
I'm running out of ideas. I have a 2006 LR3 with 200K miles. Recently having random failures that are causing all the dash lights to go on...
Dash lights
The suspension lowers and I get a transmission fault as well as HDC Fault.
I've replaced the brake switch and all the tail lights are working.
I've attached a report my scan tool put out. A LOT of temporary and Intermittent codes. Only one that is Permanent.
I can clear the codes and things will be fine for a short amount of time, then all the codes come back and the suspension lowers.
Any recommendations would be greatly appreciated.
Dash lights
You are having issues with your CAN bus network. Possibly a chaffed wire or corrosion at a connector.
Start checking for signs of water intrusion. There are many threads about these sources (sun roof drains, cowl panel, a pillar, etc.)
Edit: brake switch is still listed as an “intermittent” code. Verify it’s installed correctly and perhaps try another from a reputable brand.
Good stuff. Thanks
Thanks for the info. Brake switch is from Land Rover. Not sure if I could have installed it wrong. I’ll need to check. I live in the desert so water may not be the issue. We are just getting finished with monsoon.
QUOTE=SeattleDriver;839684]You are having issues with your CAN bus network. Possibly a chaffed wire or corrosion at a connector.
Edit: brake switch is still listed as an “intermittent” code. Verify it’s installed correctly and perhaps try another from a reputable brand.[/QUOTE]
For general diagnostics, a good Land Rover specific Independent mechanic or an automotive electrician should be find be able to find the fault source expediently.
