-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Air ride suspension compressor advise (https://landroverforums.com/forum/lr3-28/air-ride-suspension-compressor-advise-66054/)
Burfyworld Mar 25, 2014 09:58 PM
Hello Everyone,i'm new to this forum and i need advise regarding suspension compressor.i will like to know if 2005 Land Rover LR3 suspension compressor will be compatible with 2006 Land Rover LR3, I need to change it on my '06.
bbyer Mar 26, 2014 01:04 AM
yes
The compressor is the same from 2005 to 2008 so you will be OK with a compressor off a 2006 LR3.
ljdiscovery Mar 26, 2014 01:22 PM
you can actually use the compressor out of several different years. I found one out of a 2011 that was the original style. Paid about $130 delivered. Had very low miles and so far has worked great. Check on car-parts.com and search around. Squirt a bit of wd-40 on the hoses fittings before you get ready to take them off, it will save you time, frustration and time at the confessional for words you shouldn't say, ask me how I know.......Good luck.
NIM Mar 26, 2014 01:40 PM
Compressor
the new style compressor works great, i found them to be a little noisy , but they are great and will need to be program with the latest software
Crosbo Mar 28, 2014 06:10 AM
"...need to be program with the latest software"???
jafir Mar 28, 2014 01:08 PM
Yes. The original hitachi compressor and the AMK compress use different software in the ride level module. Even if you stick with the hitachi, there is updated software that is supposed to make them run cooler. I've been happy with my old hitachi with a new drier and updated software.
roverguy7 Mar 30, 2014 06:07 AM
I've found the AMK units to be much quieter then the Hitachi. Only times I've had a noisy one is when the upper half of the plastic shell was not properly installed behind the mounting bracket for the valve block, causing it to vibrate.
NIM Apr 1, 2014 10:23 AM
Yes the software need to be updated, at the dealer or some aftermarket shop that is capable to perform the update thanks Nim
