Air Suspension height and Leveling
Good Morning All!
I wanted to see if I could get some insight/info on the air suspension on my 2006 LR3. (Vehicle Stats: 2006 SE V8 with 143k. I have put Proud Rhino lift linkages on as well as A/T 32.6" tire)
Question
I reached out to the previous LR dealer who did 95% of the work, and where it was sold and then resold through auction. They stated that there were 4 possible issues on the vehicle:
Thanks for any input!
James
Question
- Is it normal for the Vehicle to drop to access height over night? 10 hrs or so?
- if so, would the difference be attributed to a fault height calibration? or a leak?
- The passenger side front is consistently 1/4" to 3/4" lower than driver side front (rear, no variation but drops to access too). It is not particularly noticeable unless it was pointed out to a layman. When I leave in the morning, I wait until the truck self-levels to driving height.
- Possible Suspension leak: Auto dealer where I purchased stated they replaced the passenger side front air susp
- Brakes: Dealer stated replaced
- Possible ball joint issue: dealer none
- VVT seal leak: dealer none
James
jbullock78 (04-26-2018)
Just a heads up, sometimes the leaks are internal in the valve blocks (leaking from a spring back into the system) so no bubbles may not mean no problems.
The system self levels, so in order to find the culprit you'll need to disable that. You can either disconnect the battery or pull the fuses in the glovebox and under the hood for the suspension. Put it up to offroad height before you do and take measurements. If the front drops, the front valve block is suspect. If the back drops, the rear one might be bad. If just one corner drops, it's likely an air spring.
jbullock78 (04-27-2018)
Good Morning All-
Thank you for all your input!
Sooo- Per djkronik (I have to change my user name to something cool) suggestion, I raised the LR to Off-road height and disconnected the battery. Measurements as follows:
730pm Sat Night
Passenger side: 20.75"
Driver side 22.00"
Rear: Both 23"
630am Sunday Morning
Passenger side: 19.5"
Driver side: 21.0"
Rear: Both 23.0"
The discrepancy has been roughly 1" between Left/Right front consistently. Measuring overnight with fuse, without fuse (F26) and with disconnected battery.
As soon as hooked the battery back up, you could hear, prominently, the drop in the rear of the LR3.
It seems like it could be the valve block for the deflation over a 11 hour period and an error in height calibration between the two front shocks.
Any thoughts?
Thanks for all your input!
James
730pm Sat Night
Driver side 22.00"
Rear: Both 23"
Driver side: 21.0"
Rear: Both 23.0"
Any thoughts?
James
