-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   any tricks to unscrew downstream 02 sensor? (https://landroverforums.com/forum/lr3-28/any-tricks-unscrew-downstream-02-sensor-91425/)
DakotaTravler Oct 6, 2018 09:26 PM
They are not identical at all, look close. With that said, they probably operate the same if installation wont interfere and it can still be plugged in.
searover83 Oct 7, 2018 04:46 PM
Hi.. and thanks for your support.. so turns out the O2 sensors are ok, just had a missing fuse in the feed circuit. .prob my fault. .duh.
I still get the EGR code P0406 - circuit A high.. and now get P2099 and P2097 .. downstream O2 sensors showing rich trim..
I guess the EGR..
what say you?
DakotaTravler Oct 7, 2018 06:00 PM
So you may have. had two issues. Odd the downstream show a code but not the upstream O2 sensors. The upstream should be more sensitive, so to speak. Are you sure the EGR valve is getting power when it should (also not missing a fuse)?
searover83 Oct 8, 2018 02:19 PM
ha. yes good point.. didnt tell you the important part.. glad you asked. The 'EGR command' reading on the iCarsoft was always 0 while driving.. and "EGR error" was 50-99%.. depending on throttle position.. (not sure how error is defined) . So you are spot on.. sounds like it's not getting the signal to open.. Need to find the pinout for the connector.. but how would I test it under proper conditions..? Would be lucky if its a bad or missing fuse..
DakotaTravler Oct 8, 2018 05:01 PM
The EGR valve should be fully closed by default (engine off, etc). And it does not operate at all RPM. So the 0 when driving might be normal. I can not say for sure as EGR systems are one thing I never really had to dig into - which also means I have no clue how that error translates either.
searover83 Oct 23, 2018 09:48 PM
update.. On a 2005 LR3 4.0 v6... so I did get the EGV1055 EGR valve, instead of the 1178, and they are different, but only in orientation of the top half, containing the sensor modules. I fixed the orientation, instead of making adjustments to the wiring and vacuum lines.. which was the other option.. anyway.. saved a bill with 10 mins of work. The EGR code that I had, P0406 . .'egr circuit A sensor high' cleared, and no CEL!! for the first 20 minute test ride. The next drive .. CEL comes on.. in 3 mins .. F*k.
Now I get P2097 .. Post Catalyst fuel trim system too rich. need to check what the sensor is outputting.. Will look for leaking/clogged exhaust or O2 sensor or wiring.. Any other ideas/comments?
TIA
