Complete Flush Brake Fluid
Hi guys,
I have a LR3 05 HSE and I will be doing a complete flush brake fluid. From all the information I have gathered I think the following are the steps I need to follow. 1- Engine on 2- Pump brake pedal 3- Engine off 4- Disconnect connector on top of brake fluid lid 5- Remove brake fluid lid 5- Fill brake reservoir with new brake fluid to Max 6- Close brake fluid lid 7- Connect a pipe on your RR bleed nipple to a empty container 8- Undo the bake bleed nipple 9- Gently press the brake pedal all the way down and let it return to the top several times 10- Make sure that brake reservoir is not getting empty 11- Confirm that new brake fluid is now going to the bleed container 12- On the last pumped brake pedal hold it down and then tighten bleed nipple 13- Let the brake pedal return to top 14- Repeat the same steps from 5 to 13 now with RL then FR and then FL bleed nipple 15- Connect connector on top of brake fluid lid Am I missing something? Am I doing something extra that is not needed? Thanks in advance, Roberto |
Read my reply on the LRO
I have an 06 LR3 SE. Can I assume the procedure is the same?
I follow this guy's methods for brakes:
https://media.disco3.co.uk/gallery/a...le_V1.4sml.pdf Speaking of, I am due again! I use Pentosin DOT4 LV (1.5L) |
