Driver side cornering lights not working, passenger side work, all 4 are new
Anyone ever run into an issue where their driver-side running lights don't work, but passenger-side do? My passenger side ones were burned out, but driver side was working. I bought 2 new LED 194 lights and started with the driver side. Once I opened it up I realized there are two lights in there (same bulb type) so I replaced both, reinstalled the driver light, and ordered two more lights. After reinstalling the driver side lights didn't work, but I chalked it up to a voltage issue with the passenger side being burned out/halogens vs. the new LEDs on the driver side.
So today I replaced the passenger side and was surprised to see both of those work, but neither of them works in the driver's side.
I'm going to swap bulbs side to side to see if the problem follows the bulb or the receptacle, but I suspect it's unlikely I got two bad LED bulbs at the same time.
Curious if anyone has run into this. Cheers!
Last edited by elemental_garage; 02-25-2022 at 07:20 PM. Reason: Cornering light changed to running light
Thats a running light, not a cornering light. The cornering lights turn on, well, when cornering at low speed and it was not an option available in the US. I think the plugs are identical for each unit, so you may be able to just try plugging the entire housing into the other side and see what happens, would greatly speed up problem solving.
Kinda wish we had em, I like extra features. Let us know either way. On a side note, careful with the lamps. Make certain you use the correct ones if you ever use incandescent. The wrong ones can melt the sockets/plastic over time form the little extra heat. Someone put 5watt in the orange side of the headlamp that you have out. It totaled it. So I now run with both sides out to match. I think the proper lamp is a W3W, not a 194, for anyone who runs em. I kinda hate LEDs in the lower front side lamp and like the incandescent look.
