-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Engine Noise on startup (https://landroverforums.com/forum/lr3-28/engine-noise-startup-66362/)
Zach.K Apr 9, 2014 08:16 AM
So I am getting a 5-10 second noise on startup. I have an 05 LR3 4.4 V8.
I just purchased this truck from the dealer a month ago and the day after I brought it home this noise started. It is back at the dealer for the second time. They said an oil change and Lucas treatment fixed it. NOPE.
See video here
I have heard it could be either a Hydraulic Lifter going bad, a VVT actuator going bad, or even the timing chain tensioner.
Worth fixing or should I just ask the dealer to keep the truck?
unseenone Apr 9, 2014 08:44 AM
What's the engine, mileage?
Some people say this develops from too infrequent oil changes.
I would have suggested the same thing, as far us a Lucas treatment and oil change. It might take some more frequent oil changes IF it is going to clear up. If they're not willing to stand behind the problem until it is solved....
Zach.K Apr 9, 2014 09:13 AM
It has 74k, I covered the engine in the first line of OP.
History on the truck is extremely well maintained. Same LR dealership for its entire life. Spoke to the service advisor yesterday who knew the PO. It had every Dealer recommended maintenance item done and all oil changes so I don't think that infrequent oil changes is the problem here.
Seeing as they have driven an hour to pick it up twice now and give me a loaner I think they are going to stand behind it. But do I want it anymore if its needing heavy engine work.
bbyer Apr 9, 2014 11:28 AM
I heard the fan ....
I guess I am not hearing what others are hearing but I did think I heard the roar of the radiator cooling fan at full lock.
If so, that is routine; some sort of emissions thing where the engine needs a load at startup to keep the EPA happy.
In colder weather or first start in morning, the fan noise is more common. Once the engine is hot, on restart, the fan lock is not so common.
Zach.K Apr 9, 2014 12:02 PM
The noise in question is the knocking\slapping noise that last aprx. 5 seconds and fades out. Metal on Metal like noise.
houm_wa Apr 9, 2014 01:07 PM
bbyer: you have to listen pretty close but yes, Zach is referring to a fairly high-frequency rattle.
roverguy7 Apr 9, 2014 05:53 PM
1 Attachment(s)
See attached.
unseenone Apr 9, 2014 08:43 PM
Thanks -- great info there...
bbyer Apr 9, 2014 10:26 PM
much appreciated
The pdf is much appreciated roverguy7.
The good news is other than knowing my engine has variable valve timing, I have not had to learn more.
The fix sounds doable in that at least the engine remains in the vehicle, you "just" have to know what to do.
Again, much appreciated.
Also, I wonder if my hearing is failing or perhaps I do not like hearing that sort of thing.
Interestingly however, I can hear when I need an oil change; at about 8,000 km (5,000 miles), a slight ticking out of the valve train becomes audible when the engine is cold. Then when I do an oil change with Castrol Syntec 5W-40, the ticking ceases. It has been that way for maybe the last 100,000 km (60,000 miles) so .....
Zach.K Apr 10, 2014 01:45 PM
That is wonderful Dave, Now when I talk to my service advisor, do I ask him about this as a TSB?, or does LR have a different term for TSB's? I only ask because I am ignorant to Land Rovers Service departments.
