-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Falcon website out of T bleeder valves? Whaddya think of this? (https://landroverforums.com/forum/lr3-28/falcon-website-out-t-bleeder-valves-whaddya-think-108129/)
svs Sep 12, 2021 09:03 PM
https://cimg1.ibsrv.net/gimg/landrov...da629963e7.jpg
I copied what someone else did on another thread here. He used a 1/4 pipe tee fip, (2) 3/8 x 1/4 mip hose barbs, and a 1/4 square hose plug. He said it worked fine. My other LR3 has the Falconworks brass T bleeder. My question is ~ will those side barbs loosen and unscrew? The whole point being that the OEM bleeder disintegrated over time unexpectedly. I dont want the irony to be this one unscrewing and leaking coolant and...you know the rest - Whaddya think guys? (For my 2nd LR3)
DakotaTravler Sep 12, 2021 09:19 PM
Whatever works, works. Its just a fitting that need to hold up to only 16psi or so.
loanrangie Sep 14, 2021 02:14 AM
Put some thread sealer on the threads.
douglastic Sep 14, 2021 04:31 PM
I chose one of these from the hardware store for a couple $
I also have a new OEM LR027661 as a backup, if I ever need to bleed from that location
https://external-content.duckduckgo....6pid%3DApi&f=1
svs Sep 14, 2021 04:50 PM
Paranoid it'll unthread.
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh!! I picked up silicone gasket. I think I need the thread lock seal instead.
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh! This is the wrong one. I need thread sealant / lock.
svs Sep 14, 2021 04:55 PM
So you're the guy who went full pipe ~
I also have a new OEM LR027661 as a backup, if I ever need to bleed from that location.
I read in one of the threads on this similar topic that someone put in a straight brass pipe. Maybe that was you. I suppose that's more solid than a bic pen tube.
Gnomadf Sep 15, 2021 10:43 AM
or they seep. And by the time it's cool enough to redo it with sealer you've compoletely forgotten about it and moved on to other chores.
steevo67 Sep 15, 2021 07:58 PM
The homemade brass tee setup you have there will work just fine and will likely never fail again, but is overkill and a bit more expensive than necessary in my opinion. When I priced out that exact setup to fix my LR3 a couple years ago, it added up to over $20 in fittings (maybe I shop at the wrong places). I've never used the upper bleeder so I "straight piped" it like douglastic described above and have never had an issue.
Gnomadf Sep 16, 2021 07:27 AM
If you have a local Rover dealership it's likely cheaper to get the part from them but if you have to add shipping it's probably going to be $20 anyways.
The straight pipe idea is really a better way to go, didn't think of that at the time I needed my tee-when mine went, I had smelled some coolant, saw the tee weeping and said "hmm", touched it and it exploded at my touch. I was liucky to not get coolant burns.
