First Post: Air Compressor/Dryer DIY Fix
#23
FYI - last weekend, I had the opportunity to work on my compressor issues (I was getting the slow raise error almost every time I drove the vehicle). Based on your writeup and experience, I decided to start with the cap. Soapy water showed the leak in the usual hairline crack spot, so I got to work trying to get the cap off without removing the compressor from the vehicle. I managed to scrape a few knuckles before figuring out that I needed better tools. Once I got a 3/8" drive with a long shaft, I was able to remove most of the end cap torx screws without a problem. A set of 90 degree angled torx tools (that look sort of like Allen wrenches, but with torx ends) did the trick for the ones that I couldn't get to as well with the long drive. From there, it was quick work to swap out the original cap with a new metal one, and so far, problem solved! So, thanks for the inspiration and the info.
-Captain Sygo
'05 LR3 SE
-Captain Sygo
'05 LR3 SE
Jona Mora (01-04-2020)
#25
@Captain Sygo - thats great!! How long did it take you to replace the cap? I would imagine the cracked dryer cap represents a decent number of the compressor failures. Being able to replace the cap without removing the compressor makes this a simple DIY fix.
@houm_wa - my writeup was for the OEM Hitachi compressor. I dont have any experience with the AMK. My indy mentioned the AMK from Land Rover was a lot better - but warned NOT to buy the AMK from Arnott.
houm_wa (11-30-2017)
#26
Surprised the Indy shop warned about Arnott's AMK compressor. It is the same basic unit now used by Land Rover but comes with a Limited Lifetime Warranty.
Arnott's AMK Air Suspension Compressor for the Range Rover Sport and the Land Rover Discovery 3 and 4, Arnott part P-2645, is designed to replace the problematic Hitachi OE compressor. This AMK air supply unit includes a bracket so it can easily replace the OE pump and bracket. This new compressor includes a release solenoid and an integrated dryer and filter. The compressor comes pre-wired with new air hoses and fittings for plug and play operation. This AMK compressor comes with vibration isolators, mounting hardware and a new compressor relay. If replacing the OE Hitachi compressor a dealer provided software update is required. You will also want to replace the Relay.
Here is a link for the installation video: https://www.youtube.com/watch?v=Pllj...ature=youtu.be
For More Information on Arnott's AMK Compressor: https://www.arnottindustries.com/pro...ge-rover-sport
#28
[QUOTE=thebruce;627643]@Captain Sygo - thats great!! How long did it take you to replace the cap? I would imagine the cracked dryer cap represents a decent number of the compressor failures. Being able to replace the cap without removing the compressor makes this a simple DIY fix.
I spent an hour and a half fussing with it and trying to make do with the short torx drive I had. Once I had the proper tools, the job went much more smoothly. I'd guess that the whole thing would have taken 30 minutes start to finish the first time, had I begun with the right equipment.
-Captain Sygo
-Captain Sygo
#30
-Captain Sygo
-Captain Sygo
Torx® Offset Screwdriver Set with Molded Handle, 5 Piece
