-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Heater blender door adjustment? (https://landroverforums.com/forum/lr3-28/heater-blender-door-adjustment-71395/)
DavC Jan 12, 2015 07:59 PM
I saw that someone (bbyer I think) had mentioned the process for testing or resetting the HVAC system with a few button presses, could anyone elaborate on any other electrical resets?
I tried holding the RECIRCULATE and ECON buttons at the same time for a period of time this afternoon, but could not get any feedback from the truck. I assume I was doing that wrong.
did test the two front zones and rear controls, all works pretty well.
How do I adjust the blender doors?
DavC Jan 12, 2015 08:20 PM
EDIT: found the post I was talking about. Works for me so I can either delete this thread or leave it as a reference. His post would make a nice sticky for anyone looking to try a simple fix.
Originally Posted by bbyer (Post 498712)
I think you guys have a damp cold down there that can feel cold but as far as the three is concerned 0F, is fairly benign.
When the temperatures get around -22F (-30C) here, (cloudy or dark, no sun), I certainly turn the seat heating on at startup and perhaps for the next 15 minutes or so. After that time, the interior is near OK if driving in the City at low speeds, (40 mph/60 kph), and out in the country at speed, (65 mph/110 kph), it might take the cabin somewhat longer to warm up. It really depends upon the cold soak - that is sitting all night or just for a few hours.
I do have the rear area second heater that I keep on manual and have set at about 3/4 fan and heat.
I usually drive with a light vest on, (coat and boots, coveralls etc in the back seat), and the windows are all clear.
I regard my heater as typical of most 3's, hence I think there is a problem with yours. It may be as simple as a thermostat stuck open or something more difficult such has having to do with the heater air doors or blend motors.
Below is a service procedure from a Land Rover HVAC service instruction sheet.
Note also my comments below as to how the procedure actually worked for me a couple of years back. Since then I have also done a software update to the HVAC that I would say fixed a perceived response concern as related to the windscreen split sunlight sensor. Since the update, I do not fiddle with the temp knobs where the sun shifts or disappears - but that is not your problem at the moment.
The motor and flap operation can be checked using the on-board distribution motor self-test function.
The self-test can be initiated by pressing and holding the ECON and RECIRC buttons while turning the ignition switch to the ON position.
The control module will then compare the current motor position with the values stored in the module and will indicate an error by flashing the ECON LED (light emitting diode).
If there are no errors, the LED will go out and the system will function normally.
To confirm that there are no errors, turn the ignition switch to the OFF position, then back to the ON position.
Observe the operation of the programmed defrost LED.
If there are errors present, the programmed defrost LED will flash and the system will attempt to calibrate itself.
My experience was when I did above as described, with the two buttons held down, the ECON light flashed as soon as the ignition was turned on, (engine off), and stayed flashing for nearly a minute or so and then sometimes either just went out, or the fan just started up normal like and the ECONO light went out.
Then when I let go of the buttons and turned the ignition off and back on, the defrost LED stayed off as if there were no problems - never did I see the defrost LED on.
I did the test procedure two or three times and figured it failed to do anything but a few days later, I was not so certain.
Maybe the weather has just warmed up; was only -20C and cloudy, snow overnight however, but now the interior of the 3 seems to warm up more like I recall it used to - fairly quickly.
Also I did some other button pushing - that was cycle a few times, each of the air up, middle air, and foot well air switches that are mounted on the left side. I started with the heater on Auto showing the two little round LEDs illuminated on the fan control; then pushed the left upper air button and let the fan run for maybe a minute; then pushed the middle button and pushed off the upper, and let the fan run for a minute or so; then the foot well button and turned off the middle button.
I did that a few times, each time seeing if air would flow out of the appropriate vents. I also manually turned the fan up to full speed so that when air did flow, there was a real blast.
What I was doing was manually trying to cycle the air doors on the chance that one or more doors just might be sticking and would perhaps un-stick themselves.
I think I may have solved a problem even if I was not certain I had one.
I have seen a few things cause this, from the heater core clogging up, the blend motor failing, and even the blend door flap in the heater box failing, both mechanically, and from the seal melting/deteriorating.
The best way that I have found to test it is as follows.
Turn Econ on, set to a medium fan speed and face level vents, and let the engine warm up.
Set one side to hot and the other to cold(not all the way, but one notch before full hot/cold)
Check temp coming out.
Change one temp to match the other.
Check the air temp again.
Reverse temp selections that were first set, one hot one cold.
Recheck temps, and then both to the same setting as above, and check one last time.
Feeling is usually enough of an indicator, no thermometer needed.
By setting one to hot and the other to cold, you limit the path of air passing over the heater core, so if it is clogging, you will still get warm air on each side by doing this. It might not be as warm one side to the other, but it will be far better then with both sides set to warm.
If the blend motor or door itself has failed, there will not be any change of temp when going from hot-cold to match the other side.
If a blend motor/door issue is found to be the case, the motor can be removed, and the door manually moved. This should give full heat on the side that there wasn't before. If it is not, then it is either the door itself not sealing, or the heater core is blocked up and wasn't checked properly above.
This is a link to a thread on heater concerns.
https://landroverforums.com/forum/lr3-28/lr3-heater-problem-39871/#post450914
If all else fails, install a new engine coolant thermostat. You are not wasting your money as eventually it will need one anyway. Also take the opportunity to pull all new coolant in as well.
bbyer Jan 16, 2015 06:32 PM
you cannot adjust the doors
I noted the question asking how to adjust the doors.
That test procedure is about the only way as it is supposed to re-educate the stepper motors and make all good. If one of the four stepper motors is sick, you have a real problem.
The link below is to some heater files plus I note there is a link in the above post as well to a pretty good thread.
Also the 3 has a charcoal fresh air inlet filter - when was the last time you replaced it?
To troubleshoot the system, I try to get the easy simple stuff right first.
Removing the fan motor will with a mirror, allow a bit of exploration in case there is a toothpick or something fouling up inside.
DISCO3.CO.UK Photo Gallery - Heater Air Conditioner System
DavC Jan 19, 2015 10:52 AM
I did eventually get the procedure to work. I got an error flash once, then the system seemed to reset. I appear to have a happily working HVAC now.
As for the filters, I changed both cabin and engine back in October, and 3 hasn't seen nearly any dust or pollen yet so I believe both are fine.
bbyer Jan 19, 2015 02:02 PM
first I have heard ...
That is good news - that the test procedure appears to have worked.
You are the first person I have heard from that could probably say that the procedure did good. It is supposed to but it certainly is good to hear of it apparently working - thanks for the update.
Re the filters, some do not even know the HVAC system has an internal charcoal filter, hence the knowledge of it is well, news. The best test of the charcoal HVAC filter is that when parked behind a cattle truck, to open a side window. You very quickly then know the charcoal is working amazingly well.
Thanks for the update.
LR3Kludge Dec 19, 2022 11:53 AM
Found how to get the calibration to work.
I know this is an old thread but I figured out how to make the calibration work. See edit below in bold:
If there are no errors, the LED will go out and the system will function normally. As soon as the ECON LED starts blinking, turn the ignition switch to OFF, then back to ON, Now the defrost light will blink and will start the calibration. This fixed my driver's side which would only blow lukewarm air when turned to fully hot. Also, this process seem to have worked best when I started it with both the passenger side and driver's side set to max cold.
redbarnengineering Feb 7, 2023 11:00 AM
I did all of this including taking the blend motor out and verify it moves and still same cool air on drivers hot on passenger. I think the next step is flush the core.
Valdim Feb 7, 2023 03:12 PM
Blend motor change
Hi,
How difficult was driver side blend motor to be taken out?
Could you send a short description of the process?
Did you manage the solve the problem?
I have the same story with my LR3
redbarnengineering Feb 7, 2023 06:19 PM
Originally Posted by Valdim (Post 854828)
Hi,
Have to remove the center console then the radio/hvac clusters so you can remove the middle dash shroud. Also remove all the lower dash covers on the drivers footwell. Once you have all that out you can see the blend motor from drivers side tucked up above the blending box with the heater core. There are 3 screws holding it in.
Unfortunately it turns out the blend motor was still functioning. You can hold it and turn the temp up and down and see it move. I manually moved the blend door with the blower on and there was no difference. I am going to flush out the heater core next.
