Height Sensor failing question
Old 08-20-2018, 04:37 AM
jbullock78's Avatar
Default Height Sensor failing question
Hello All,
I was stranded on my bump stops about 100 miles from home after a fairly aggressive off-roading session (very rocky) recently and had a local repair shop service my 2006 LR3 145k.
They had to do a lot of trial and error (obvious ha!) they ended up replacing the right height sensors. (right side)
My question is, how often do they fail? would a IID Tool help if in case i get stuck on a trail (the sensor failed when i got back on the pavement)?
I just want to be more prepared-
Thank you!
James
Old 08-20-2018, 02:27 PM
houm_wa's Avatar
Absolutely. I always have a few spare sensors in my parts kit, and I don't go anywhere without the IIDTool.
A height sensor is fairly easy to install and if it goes bad the results can mess you up big time, as you well know. I wonder, how many times is the issue really the sensor versus the calibration.
jbullock78 (08-20-2018)
Old 08-20-2018, 03:36 PM
jbullock78's Avatar
if the sensor/s failed would the IID tool be able to re-level to road height?
Old 08-20-2018, 05:39 PM
houm_wa's Avatar
You can momentarily get the EAS back to an appropriate height, then pull the fuses, as a "get home" procedure.
Old 08-20-2018, 07:09 PM
jbullock78's Avatar
Thank you-
I would hate to go with a misunderstanding of the IID tools capability-
Old 08-20-2018, 10:21 PM
houm_wa's Avatar
You're welcome...I've had it happen to me. I was in the forest, had a sway bar link snap because my air shock had failed inasmuch as it was no longer limiting travel and the upper control arm was wacking it. I think in the process my bracket holding the height sensor in that corner got tweaked and that messed up the calibration.
I used the IIDTool to get off the bumpstops, and then pulled the EAS fuses and tip-toed out of the forest. A few things stood out to me through that experience:
1. WOW! The LR3 an really ball out on a trail. Even in that state, I walked over a legit trail without spinning a tire.
2. EAS failures that result in bumpstops are fairly rare and usually preventable. If I had recognized the symptoms I was experiencing in the months leading up to that event, I would have known that the shock was failing. I should have...because I read this damn forum so much, but at the time I didn't.
3. The IIDTool is invaluable.
Old 08-20-2018, 10:31 PM
jbullock78's Avatar
Excellent-
Yea prior to the fault I hit a difficult ATV trail and it was spectacular on the trail- I was really surprised :-)
Next pay period- I will get the IID tool.
James Atop Peters Mill Run on the Green Mountain Trail (457) George Washington Nat Forest Virginia
Old 08-20-2018, 10:47 PM
houm_wa's Avatar
Good plan!
TOM R
06-14-2021 12:15 AM
Identamerican
08-31-2019 09:24 PM
zoltan7
04-12-2017 08:32 AM
p8nt
08-16-2013 12:58 PM
Quick Reply: Height Sensor failing question
